Stability estimates for a Robin coefficient in the two-dimensional Stokes system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Control and Related Fields Année : 2013
In this paper, we consider the Stokes equations and we are concerned with the inverse problem of identifying a Robin coefficient on some non accessible part of the boundary from available data on the other part of the boundary. We first study the identifiability of the Robin coefficient and then we establish a stability estimate of logarithm type thanks to a Carleman inequality due to A. L. Bukhgeim and under the assumption that the velocity of a given reference solution stays far from 0 on a part of the boundary where Robin conditions are prescribed.
stabilite_stokes2_cor.pdf (513.06 Ko) Télécharger le fichier
hal-00582559 , version 1 (01-04-2011)
hal-00582559 , version 2 (06-02-2012)
hal-00582559 , version 3 (04-12-2012)
Muriel Boulakia, Anne-Claire Egloffe, Céline Grandmont. Stability estimates for a Robin coefficient in the two-dimensional Stokes system. Mathematical Control and Related Fields, 2013, 3 (1), https://www.aimsciences.org/journals/pdfs.jsp?paperID=8296&mode=full. ⟨hal-00582559v3⟩
555 Consultations
335 Téléchargements
