A service discovery and automatic deployment component-based software infrastructure for Ubiquitous Computing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Software applications running on mobile devices are more and more needed. These applications have strong requirements to address: device heterogeneity, limited resources, networked communications, and security. Moreover it is required to have appropriate application design, discovery, deployment, and execution paradigms. These requirements are similar to those of any ubiquitous computing application. In this paper, we present a component-based software infrastructure to design, discover, deploy, and execute ubiquitous computing contextual applications. Applications are designed as assemblies of distributed software components. These assemblies are dynamically discovered according to end-users' physical location and device capabilities. Then appropriate assemblies are automatically deployed on users' devices. Ubiquitous contextual services and our software infrastructure are built on top of the OMG's CORBA Component Model (CCM) and are implemented using the OpenCCM platform. As illustration, a service to get information about departure trains is described in detail.
umics05.pdf (386.65 Ko) Télécharger le fichier
hal-00583033 , version 1 (25-02-2013)
  • HAL Id : hal-00583033 , version 1
Areski Flissi, Christophe Gransart, Philippe Merle. A service discovery and automatic deployment component-based software infrastructure for Ubiquitous Computing. The 17th Conference on Advanced Information Systems Engineering - CAiSE'05 Workshop, Jun 2005, Porto, Portugal. pp.601-615. ⟨hal-00583033⟩
242 Consultations
125 Téléchargements
