Smooth density for some nilpotent rough differential equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Theoretical Probability Année : 2013
In this note, we provide a non trivial example of differential equation driven by a fractional Brownian motion with Hurst parameter 1/3 < H < 1/2, whose solution admits a smooth density with respect to Lebesgue's measure. The result is obtained through the use of an explicit representation of the solution when the vector fields of the equation are nilpotent, plus a Norris type lemma in the rough paths context.
h-t-norris8.pdf (312.8 Ko) Télécharger le fichier
hal-00584938 , version 1 (11-04-2011)
Yaozhong Hu, Samy Tindel. Smooth density for some nilpotent rough differential equations. Journal of Theoretical Probability, 2013, 26 (3), pp.722-749. ⟨10.1007/s10959-011-0388-x⟩. ⟨hal-00584938⟩
255 Consultations
172 Téléchargements
