Strong solutions for a phase field Navier-Stokes vesicle-fluid interaction model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Mathematical Fluid Mechanics Année : 2012
In this paper we study a mathematical model for the dynamics of vesicle membranes in a 3D incompressible viscous fluid. The system is in the Eulerian formulation, involving the coupling of the incompressible Navier-Stokes system with a phase field equation. This equation models the vesicle deformations under external flow fields. We prove the local in time existence and uniqueness of strong solutions. Moreover, we show that, given T > 0, for initial data which are small (in terms of T), these solutions are defined on [0, T] (almost global existence).
hal-00590656 , version 1 (04-05-2011)
Yuning Liu, Takéo Takahashi, Marius Tucsnak. Strong solutions for a phase field Navier-Stokes vesicle-fluid interaction model. Journal of Mathematical Fluid Mechanics, 2012, 14 (1), pp.177-195. ⟨10.1007/s00021-011-0059-9⟩. ⟨hal-00590656⟩
151 Consultations
0 Téléchargements
