High-Order Optimal Edge Elements for Pyramids, Prisms and Hexahedra - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2013
Edge elements are a popular method to solve Maxwell's equations especially in time-harmonic domain. However, when non-affine elements are considered, elements of the Nedelec's first family are not providing an optimal rate of the convergence of the numerical solution toward the solution of the exact problem in H(curl)-norm. We propose new finite element spaces for pyramids, prisms, and hexahedra in order to recover the optimal convergence. In the particular case of pyramids, a comparison with other existing elements found in the literature is performed. Numerical results show the good behaviour of these new finite elements.
PyramidsHcurl-JCP.pdf (970.75 Ko) Télécharger le fichier
hal-00605963 , version 1 (05-07-2011)
hal-00605963 , version 2 (10-08-2012)
Morgane Bergot, Marc Duruflé. High-Order Optimal Edge Elements for Pyramids, Prisms and Hexahedra. Journal of Computational Physics, 2013, 232 (1), pp.189-213. ⟨10.1016/j.jcp.2012.08.005⟩. ⟨hal-00605963v2⟩
328 Consultations
750 Téléchargements
