Structured sparsity through convex optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Statistical Science Année : 2012
Sparse estimation methods are aimed at using or obtaining parsimonious representations of data or models. While naturally cast as a combinatorial optimization problem, variable or feature selection admits a convex relaxation through the regularization by the $\ell_1$-norm. In this paper, we consider situations where we are not only interested in sparsity, but where some structural prior knowledge is available as well. We show that the $\ell_1$-norm can then be extended to structured norms built on either disjoint or overlapping groups of variables, leading to a flexible framework that can deal with various structures. We present applications to unsupervised learning, for structured sparse principal component analysis and hierarchical dictionary learning, and to supervised learning in the context of non-linear variable selection.
stat_science_structured_sparsity_final_version.pdf (739.83 Ko) Télécharger le fichier
hal-00621245 , version 1 (09-09-2011)
hal-00621245 , version 2 (20-04-2012)
Francis Bach, Rodolphe Jenatton, Julien Mairal, Guillaume Obozinski. Structured sparsity through convex optimization. Statistical Science, 2012, To appear. ⟨hal-00621245v2⟩
505 Consultations
598 Téléchargements
