The strong relaxation limit of the multidimensional Euler equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nonlinear Differential Equations and Applications Année : 2013
This paper is devoted to the analysis of global smooth solutions to the multidimensional isentropic Euler equations with sti relaxation. We show that the asymptotic behavior of the global smooth solution is governed by the porous media equation as the relaxation time tends to zero. The results are proved by combining some classical energy estimates with the so-called Shizuta-Kawashima condition.
LC.pdf (290.8 Ko) Télécharger le fichier
hal-00622938 , version 1 (13-09-2011)
Chunjin Lin, Jean-François Coulombel. The strong relaxation limit of the multidimensional Euler equations. Nonlinear Differential Equations and Applications, 2013, 20 (3), pp.447-461. ⟨10.1007/s00030-012-0159-0⟩. ⟨hal-00622938⟩
267 Consultations
240 Téléchargements
