On dominance-based multiobjective local search: design, implementation and experimental analysis on scheduling and traveling salesman problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Heuristics Année : 2012
This paper discusses simple local search approaches for approximating the efficient set of multiobjective combinatorial optimization problems. We focus on algorithms defined by a neighborhood structure and a dominance relation that iteratively improve an archive of nondominated solutions. Such methods are referred to as dominance-based multiobjective local search. We first provide a concise overview of existing algorithms, and we propose a model trying to unify them through a fine-grained decomposition. The main problem-independent search components of dominance relation, solution selection, neighborhood exploration and archiving are largely discussed. Then, a number of state-of-the-art and original strategies are experimented on solving a permutation flowshop scheduling problem and a traveling salesman problem, both on a two- and a three-objective formulation. Experimental results and a statistical comparison are reported in the paper, and some directions for future research are highlighted.
liefooghe_heur2012.pdf (444.63 Ko) Télécharger le fichier
hal-00628215 , version 1 (03-05-2023)
hal-00628215 , version 2 (05-05-2023)
Arnaud Liefooghe, Jérémie Humeau, Salma Mesmoudi, Laetitia Jourdan, El-Ghazali Talbi. On dominance-based multiobjective local search: design, implementation and experimental analysis on scheduling and traveling salesman problems. Journal of Heuristics, 2012, 18 (2), pp.317-352. ⟨10.1007/s10732-011-9181-3⟩. ⟨hal-00628215v2⟩
322 Consultations
39 Téléchargements
