Asymptotic Behavior of Green Functions of Divergence form Operators with Periodic Coefficients - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applied Mathematics Research eXpress Année : 2013
This article is concerned with the asymptotic behavior, at infinity and at the origin, of Green functions of operators of the form Lu= −div(A∇u), where A is a periodic, coercive, and bounded matrix.
blanc_legoll_anantharaman_AMRX_2013.pdf (236.17 Ko) Télécharger le fichier
hal-01079280 , version 1 (31-10-2014)
Xavier Blanc, Frédéric Legoll, Arnaud Anantharaman. Asymptotic Behavior of Green Functions of Divergence form Operators with Periodic Coefficients. Applied Mathematics Research eXpress, 2013, 2013, pp.79 - 101. ⟨10.1093/amrx/abs013⟩. ⟨hal-01079280⟩
Relations
351 Consultations
705 Téléchargements
