Experimental Evaluation of Autonomous Driving Based on Visual Memory and Image Based Visual Servoing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Intelligent Transportation Systems Année : 2011
In this paper, the performance of a topological metric visual-path-following framework is investigated in different environments. The framework relies on a monocular camera as the only sensing modality. The path is represented as a series of refer- ence images such that each neighboring pair contains a number of common landmarks. Local 3-D geometries are reconstructed between the neighboring reference images to achieve fast feature prediction. This condition allows recovery from tracking failures. During navigation, the robot is controlled using image-based vi- sual servoing. The focus of this paper is on the results from a num- ber of experiments that were conducted in different environments, lighting conditions, and seasons. The experiments with a robot car show that the framework is robust to moving objects and moderate illumination changes. It is also shown that the system is capable of online path learning.
Mots clés
2011_its_diosi.pdf (1.45 Mo) Télécharger le fichier
hal-00639680 , version 1 (09-11-2011)
  • HAL Id : hal-00639680 , version 1
A. Diosi, S. Segvic, A. Remazeilles, F. Chaumette. Experimental Evaluation of Autonomous Driving Based on Visual Memory and Image Based Visual Servoing. IEEE Transactions on Intelligent Transportation Systems, 2011, 12 (3), pp.870-883. ⟨hal-00639680⟩
277 Consultations
439 Téléchargements
