Distributed Orchestration of Web Services under Security Constraints
We present a novel approach to automated distributed orchestration of Web Services tied with security policies. The construction of an orchestration complying with the policies is based on the resolution of deducibility constraint systems and has been implemented for the non-distributed case as part of the AVANTSSAR Validation Platform. The tool has been successfully experimented on several case-studies from industry and academia.
Ingénierie assistée par ordinateur
