Towards modelling the activity of design: An observational study on a specification stage - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1988
Willemien Visser
  • Fonction : Auteur
  • PersonId : 829708
We conducted three weeks full time observations on a mechanic participating in a real, complex, industrial design project. The task observed was the specification of the operative part of an automatized machine tool installation. The method of simultaneous verbalization was used for collecting data on the mechanic's design activity. In this article, we present the general architecture of a part of a model of this activity as we derived it from the observations we analyzed until now. We divided the mechanic's solution space in different goal spaces. Control procedures formalized as production rules govern the transitions within a goal space (between the procedures in it) and between different goal spaces. The central articulation of goal spaces was presented as being hierarchical, following the mechanic's description of his plan, but control rules for goal changes abandoning this plan were formulated to account for our observations of goal deviation. Design appears not to be an exclusively hierarchically organized plan-guided activity. This result leads us to favor an opportunistic model which can incorporate the possibility for plan-guided contributions without being exclusively governed by such a plan.
Des observations ont été menées auprès d'un concepteur mécanique tout au long de sa tâche de définition des spécifications fonctionnelles de la partie opérative d'une installation automatisée de machine-outil. Le concepteur décrivait son activité comme suivant un plan structuré hiérarchiquement. Ce plan, cependant, ne rend pas compte de son activité qui est en fait organisée de façon opportuniste. Le concepteur suit son plan tant que celui-ci est intéressant du point de vue du coût cognitif des actions proposées. Dès que d'autres actions sont plus intéressantes, il dévie de son plan pour procéder à celles-ci. Cet article présente l'architecture générale d'une partie d'un modèle de cette activité basée sur l'analyse d'une partie des observations. L'espace de solution du concepteur est divisé en différents espaces liés aux buts poursuivis. Des procédures de contrôle formalisées comme des règles de production gouvernent les transitions à l'intérieur d'un espace lié à un but (entre les procédures dans l'espace) et entre différents espaces liés à des buts. L'articulation centrale des espaces liés à des buts est présenté comme une structure hiérarchique, selon la description de son plan par le concepteur, mais des règles de contrôle pour les changements de but conduisant à des déviations de ce plan ont été formulées pour rendre compte des déviations observées. La conclusion que la conception ne semble pas être une activité organisée de façon exclusivement hiérarchique favorise un modèle opportuniste qui peut incorporer des possibilités de contributions guidées par un plan, sans être gouverné exclusivement par un tel plan.
WVisser_IFAC88.pdf (88.89 Ko) Télécharger le fichier
hal-00641401 , version 1 (15-11-2011)
  • HAL Id : hal-00641401 , version 1
Willemien Visser. Towards modelling the activity of design: An observational study on a specification stage. IFAC/IFIP/IEA/IFORS Conference on Man-Machine Systems. Analysis, Design and Evaluation, IFAC/IFIP/IEA/IFORS, Jun 1988, Oulu, Finland. ⟨hal-00641401⟩
Collections
INRIA INRIA2
186 Consultations
274 Téléchargements
