hal-00643000, version 1
A Robust Ranking Methodology based on Diverse Calibration of AdaBoost
Róbert Busa-Fekete 1Balázs Kégl
1, 2, 3Tamas Elteto
a, 3György Szarvas 4
European Conference on Machine Learning (ECML 2011) (2011)
Résumé : In subset ranking, the goal is to learn a ranking function that approximates a gold standard partial ordering of a set of objects (in our case, relevance labels of a set of documents retrieved for the same query). In this paper we introduce a learning to rank approach to subset ranking based on multi-class classification. Our technique can be summarized in three major steps. First, a multi-class classification model (AdaBoost.MH) is trained to predict the relevance label of each object. Second, the trained model is calibrated using various calibra- tion techniques to obtain diverse class probability estimates. Finally, the Bayes-scoring function (which optimizes the popular Information Re- trieval performance measure NDCG), is approximated through mixing these estimates into an ultimate scoring function. An important novelty of our approach is that many different methods are applied to estimate the same probability distribution, and all these hypotheses are combined into an improved model. It is well known that mixing different condi- tional distributions according to a prior is usually more efficient than selecting one "optimal" distribution. Accordingly, using all the calibra- tion techniques, our approach does not require the estimation of the best suited calibration method and is therefore less prone to overfitting. In an experimental study, our method outperformed many standard ranking algorithms on the LETOR benchmark datasets, most of which are based on significantly more complex learning to rank algorithms than ours.
- a – TAO
- 1 : Laboratoire de l'Accélérateur Linéaire (LAL)
- CNRS : UMR8607 – IN2P3 – Université Paris XI - Paris Sud
- 2 : Laboratoire de Recherche en Informatique (LRI)
- CNRS : UMR8623 – Université Paris XI - Paris Sud
- 3 : TAO (INRIA Saclay - Ile de France)
- INRIA – CNRS : UMR8623 – Université Paris XI - Paris Sud
- 4 : Ubiquitous Knowledge Processing (UKP) Lab
- Technische Universität Darmstad
- Domaine : Informatique/Apprentissage
- Référence interne : LAL 11-309
- hal-00643000, version 1
- http://hal.inria.fr/hal-00643000
- oai:hal.inria.fr:hal-00643000
- Contributeur : Balázs Kégl
- Soumis le : Dimanche 20 Novembre 2011, 22:50:34
- Dernière modification le : Mardi 30 Octobre 2012, 17:04:57
Documents associés
Exporter
