Approximation of the Fokker-Planck equation of the stochastic chemostat - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematics and Computers in Simulation Année : 2014
We consider a stochastic model of the two-dimensional chemostat as a diffusion process for the concentration of substrate and the concentration of biomass. The model allows for the washout phenomenon: the disappearance of the biomass inside the chemostat. We establish the Fokker-Planck associated with this diffusion process, in particular we describe the boundary conditions that modelize the washout. We propose an adapted finite difference scheme for the approximation of the solution of the Fokker-Planck equation.
paper-chemostat-DF.pdf (306.9 Ko) Télécharger le fichier
hal-00644250 , version 1 (24-11-2011)
Fabien Campillo, Marc Joannides, Irène Larramendy-Valverde. Approximation of the Fokker-Planck equation of the stochastic chemostat. Mathematics and Computers in Simulation, 2014, 99, pp.37-53. ⟨10.1016/j.matcom.2013.04.012⟩. ⟨hal-00644250⟩
355 Consultations
412 Téléchargements
