Analysis of an M/G/1 queue with customer impatience and adaptive arrival process - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We study an M/G/1 queue with impatience and an adaptive arrival process. The rate of the arrival process changes according to whether an incoming customer is accepted or rejected. We analyse two different models for impatience : (i) based on workload, and (ii) based on queue-length. For the workload-based model, we obtain the Laplace-Stieltjes Transform of the joint stationary workload and arrival rate process, and that of the waiting time. For the queue-length based model we obtain the analogous z-transform. These queueing models might also be useful for capturing the interaction between congestion control algorithms and queue management schemes in the Internet.
23-PID2139415.pdf (111.97 Ko) Télécharger le fichier
hal-00644866 , version 1 (25-11-2011)
  • HAL Id : hal-00644866 , version 1
Onno Boxma, Balakrishna Prabhu. Analysis of an M/G/1 queue with customer impatience and adaptive arrival process. NetGCOOP 2011 : International conference on NETwork Games, COntrol and OPtimization, Telecom SudParis et Université Paris Descartes, Oct 2011, Paris, France. ⟨hal-00644866⟩
103 Consultations
60 Téléchargements
