Towards Transactional Memory Support for GCC - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Transactional memory is a parallel programming model providing many advantages over lock-based concurrency. It is one important attempt to exploit the potential of multicore architectures while preserving software development productivity. This paper describes the design of a transactional memory extension for GCC, and highlights research challenges and perspectives enabled by this design.
grow09.pdf (127.98 Ko) Télécharger le fichier
hal-00645337 , version 1 (28-11-2011)
  • HAL Id : hal-00645337 , version 1
Martin Schindewolf, Albert Cohen, Wolfgang Karl, Andrea Marongiu, Luca Benini. Towards Transactional Memory Support for GCC. 1st GCC Research Opportunities Workshop, Jan 2009, Paphos, Cyprus. ⟨hal-00645337⟩
264 Consultations
676 Téléchargements
