s'authentifier
version française rss feed
hal-00646421, version 1
High-Order Schemes Combining the Modified Equation Approach and Discontinuous Galerkin Approximations for the Wave Equation
Cyril Agut () 12, Julien Diaz () 12, Abdelaâziz Ezziani () a12
Communications in Computational Physics 11, 2 (2012) 691-708
Résumé : We present a new high ordermethod in space and time for solving the wave equation, based on a newinterpretation of the "Modified Equation" technique. Indeed, contrary to most of the works, we consider the time discretization before the space discretization. After the time discretization, an additional biharmonic operator appears, which can not be discretized by classical finite elements. We propose a new Discontinuous Galerkinmethod for the discretization of this operator, and we provide numerical experiments proving that the new method is more accurate than the classicalModified Equation technique with a lower computational burden.
  • Domaine : Mathématiques/Equations aux dérivées partielles
  • hal-00646421, version 1
  • oai:hal.inria.fr:hal-00646421
  • Contributeur :
  • Soumis le : Mardi 29 Novembre 2011, 22:39:31
  • Dernière modification le : Samedi 3 Décembre 2011, 19:05:56
tous les articles de la base du CCSd...
