Switching, relay and complementarity systems: A tutorial on their well-posedness and relationships - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physica D: Nonlinear Phenomena Année : 2012
This paper reviews the relationships between switching systems defined from a partition of the state space into convex cells, and relay or complementarity dynamical systems, which are other classes of discontinuous systems. Well-posedness results (i.e. results on the existence and the uniqueness of solutions) for different classes of relay and complementarity systems which are also switching systems are presented. The reverse issue (when can a switching system be rewritten equivalently as a relay or a complementarity system) is also tackled. Many examples from Mechanics, Circuits, and Biology illustrate the developments throughout the paper. The paper focuses on systems with continuous solutions (i.e. with no state jumps). Convexity is the central property.
RR-7760.pdf (761.44 Ko) Télécharger le fichier
hal-00646982 , version 1 (01-02-2013)
Carmina Georgescu, Bernard Brogliato, Vincent Acary. Switching, relay and complementarity systems: A tutorial on their well-posedness and relationships. Physica D: Nonlinear Phenomena, 2012, Dynamics and Bifurcations of Nonsmooth Systems, 241 (22), pp.50. ⟨10.1016/j.physd.2011.10.014⟩. ⟨hal-00646982⟩
279 Consultations
446 Téléchargements
