Exploiting Addresses Correlation to Maximize Lifetime of IPv6 Cluster-based WSNs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Improving the network lifetime is an important design criterion for wireless sensor networks. To achieve this goal, we propose in this paper a novel approach which applies source-coding on addresses in heterogeneous IPv6 Cluster-based wireless sensor network. We formulate the problem of maximiz- ing the network lifetime when Slepian-wolf coding is applied on addresses in network composed of line-powered and battery- powered sensors. This problem optimizes the placement of line- powered sensors to enable the battery-powered ones to exploit the addresses correlation and reduce the size of their emitted packets and thus improve the network lifetime. The numerical results show that a significant network lifetime improvement can be achieved (about 25% in typical scenario).
correlation.pdf (153.96 Ko) Télécharger le fichier
hal-00647870 , version 1 (02-12-2011)
  • HAL Id : hal-00647870 , version 1
Leila Ben Saad, Bernard Tourancheau. Exploiting Addresses Correlation to Maximize Lifetime of IPv6 Cluster-based WSNs. WiMob, the International conference on wireless and mobile computing, networking and communications, STWiMob workshop, Oct 2011, Sanghai, China. ⟨hal-00647870⟩
253 Consultations
260 Téléchargements
