Efficient computation of clipped Voronoi diagram for mesh generation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer-Aided Design Année : 2011
Dong-Ming Yan
  • Fonction : Auteur
  • PersonId : 885221
Wenping Wang
  • Fonction : Auteur
  • PersonId : 885224
Bruno Lévy
Yang Liu
  • Fonction : Auteur
  • PersonId : 885222
The Voronoi diagram is a fundamental geometric structure widely used in various fields, especially in computer graphics and geometry computing. For a set of points in a compact domain (i.e. a bounded and closed 2D region or a 3D volume), some Voronoi cells of their Voronoi diagram are infinite or partially outside of the domain, but in practice only the parts of the cells inside the domain are needed, as when computing the centroidal Voronoi tessellation. Such a Voronoi diagram confined to a compact domain is called a clipped Voronoi diagram. We present an efficient algorithm to compute the clipped Voronoi diagram for a set of sites with respect to a compact 2D region or a 3D volume. We also apply the proposed method to optimal mesh generation based on the centroidal Voronoi tessellation.
main.pdf (27.34 Mo) Télécharger le fichier
hal-00647979 , version 1 (05-12-2011)
Dong-Ming Yan, Wenping Wang, Bruno Lévy, Yang Liu. Efficient computation of clipped Voronoi diagram for mesh generation. Computer-Aided Design, 2011, ⟨10.1016/j.cad.2011.09.004⟩. ⟨hal-00647979⟩
293 Consultations
2456 Téléchargements
