Boltzmann machine and mean-field approximation for structured sparse decompositions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2012
Taking advantage of the structures inherent in many sparse decompositions constitutes a promising research axis. In this paper, we address this problem from a Bayesian point of view. We exploit a Boltzmann machine, allowing to take a large variety of structures into account, and focus on the resolution of a marginalized maximum a posteriori problem. To solve this problem, we resort to a mean-field approximation and the variational Bayes Expectation-Maximization" algorithm. This approach results in a soft procedure making no hard decision in the support or the values of the sparse representation. We show that this characteristic leads to an improvement of the performance over state-of-the-art algorithms.
manuscript.pdf (473.39 Ko) Télécharger le fichier
hal-00648089 , version 1 (05-12-2011)
hal-00648089 , version 2 (16-03-2012)
  • HAL Id : hal-00648089 , version 2
Angélique Drémeau, Cédric Herzet, Laurent Daudet. Boltzmann machine and mean-field approximation for structured sparse decompositions. 2012. ⟨hal-00648089v2⟩
497 Consultations
1142 Téléchargements
