Study of different strategies for splitting variables in multidisciplinary topology optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2011
This paper is devoted to the minimization of the thickness of an elastic structure under competitive loadings. We propose to determine an equilibrium thickness using game theory. We consider two loads exercised separately on two parts of the plate and we aim to optimize both compliances so we deal with a multiloading optimization problem. Firstly, the design variable is taken to be the thickness of the plate. In a second step, we assume that the thickness depends on two independent functions, that we consider as strategies. The multidisciplinary optimization problem is solved as a non-cooperative game and we determine a Nash equilibrium. Finally, some numerical simulations are presented and discuted.
plaquecantilever.pdf (2.33 Mo) Télécharger le fichier
hal-00648701 , version 1 (06-12-2011)
  • HAL Id : hal-00648701 , version 1
Rajae Aboulaich, Abderrahmane Habbal, Noureddine Moussaid. Study of different strategies for splitting variables in multidisciplinary topology optimization. 2011. ⟨hal-00648701⟩
344 Consultations
184 Téléchargements
