Mathematical model of the primary CD8 T cell immune response: stability analysis of a nonlinear age-structured system. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Mathematical Biology Année : 2012
The primary CD8 T cell immune response, due to a first encounter with a pathogen, happens in two phases: an expansion phase, with a fast increase of T cell count, followed by a contraction phase. This contraction phase is followed by the generation of memory cells. These latter are specific of the antigen and will allow a faster and stronger response when encountering the antigen for the second time. We propose a nonlinear mathematical model describing the T CD8 immune response to a primary infection, based on three nonlinear ordinary differential equations and one nonlinear age-structured partial differential equation, describing the evolution of CD8 T cell count and pathogen amount. We discuss in particular the roles and relevance of feedback controls that regulate the response. First we reduce our system to a system with a nonlinear differential equation with a distributed delay. We study the existence of two steady states, and we analyze the asymptotic stability of these steady states. Second we study the system with a discrete delay, and analyze global asymptotic stability of steady states. Finally, we show some simulations that we can obtain from the model and confront them to experimental data.
hal-00649219 , version 1 (07-12-2011)
Emmanuelle Terry, Jacqueline Marvel, Christophe Arpin, Olivier Gandrillon, Fabien Crauste. Mathematical model of the primary CD8 T cell immune response: stability analysis of a nonlinear age-structured system.. Journal of Mathematical Biology, 2012, 65, pp.263-291. ⟨10.1007/s00285-011-0459-8⟩. ⟨hal-00649219⟩
303 Consultations
0 Téléchargements
