Full reduction at full throttle - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Lecture Notes in Computer Science Année : 2011
Emerging trends in proof styles and new applications of interactive proof assistants exploit the computational facilities of the provided proof language, reaping enormous benefits in proof size and convenience to the user. However, the resulting proof objects really put the proof assistant to the test in terms of computational time required to check them. We present a novel translation of the terms of the full Calculus of (Co)Inductive Constructions to OCAML programs. Building on this translation, we further present a new fully featured version of COQ that offloads much of the computation required during proof checking to a vanilla, state of the art and fine tuned compiler. This modular scheme yields substantial performance improvements over existing systems at a reduced implementation cost. The work presented here builds on previous work described in [GL02], but we place particular emphasis in this paper on the fact that this scheme is in fact an instance of untyped normalization by evaluation [FR04, Lin05, AHN08, Boe10].
full_throttle.pdf (147.13 Ko) Télécharger le fichier
hal-00650940 , version 1 (12-12-2011)
Mathieu Boespflug, Maxime Dénès, Benjamin Grégoire. Full reduction at full throttle. Certified Programs and Proofs, Dec 2011, Kenting, Taiwan. ⟨10.1007/978-3-642-25379-9_26⟩. ⟨hal-00650940⟩
Collections
INRIA INRIA2
980 Consultations
622 Téléchargements
