A relaxation of Coq's guard condition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In a convenient language to handle dependent algebraic data types, this article describes how commutative cuts are used to tackle dependency in pattern matching. It defines a new termination criteria by structural guard condition that allows commutative cuts. Everything exposed scales directly to the Coq proof assistant and describes its implementation. The proof of strong normalisation does not and is still work to do.
boutillier.pdf (203.42 Ko) Télécharger le fichier
hal-00651780 , version 1 (14-12-2011)
  • HAL Id : hal-00651780 , version 1
Pierre Boutillier. A relaxation of Coq's guard condition. JFLA - Journées Francophones des langages applicatifs - 2012, Feb 2012, Carnac, France. pp.1 - 14. ⟨hal-00651780⟩
213 Consultations
327 Téléchargements
