Refactoring Composite to Visitor and Inverse Transformation in Java - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2013
Akram Ajouli
  • Fonction : Auteur
  • PersonId : 765331
  • IdRef : 172287197
We describe how to use refactoring tools to transform a Java program conforming to the Composite design pattern into a program conforming to the Visitor design pattern with the same external behavior. We also describe the inverse transformation. We use the refactoring tool provided by IntelliJ IDEA.
rapport.pdf (1.44 Mo) Télécharger le fichier
hal-00652872 , version 1 (16-12-2011)
hal-00652872 , version 2 (30-11-2012)
hal-00652872 , version 3 (01-07-2013)
Akram Ajouli, Julien Cohen. Refactoring Composite to Visitor and Inverse Transformation in Java. 2013. ⟨hal-00652872v3⟩
503 Consultations
609 Téléchargements
