Rich Intrinsic Image Separation for Multi-View Outdoor Scenes
Intrinsic images aim at separating an image into its reflectance and illumination components to facilitate further analysis or manipulation. This separation is severely ill-posed and the most successful methods rely on user indications or precise geometry to resolve the ambiguities inherent to this problem. In this paper we propose a method to estimate intrinsic images from multiple views of an outdoor scene without the need for precise geometry or involved user intervention. We use multiview stereo to automatically reconstruct a 3D point cloud of the scene. Although this point cloud is sparse and incomplete, we show that it provides the necessary information to compute plausible sky and indirect illumination at each 3D point. We then introduce an optimization method to estimate sun visibility over the point cloud. This algorithm compensates for the lack of accurate geometry and allows the extraction of precise shadows in the final image. We finally propagate the information computed over the sparse point cloud to every pixel in the photograph using image-guided propagation. Our propagation not only separates reflectance from illumination, but also decomposes the illumination into a sun, sky and indirect layer. This rich decomposition allows novel image manipulations as demonstrated by our results.
Nous présentons une méthode capable de décomposer les photographies d'une scène en trois composantes intrinsèques --- la réflectance, l'illumination due au soleil, l'illumination due au ciel, et l'illumination indirecte. L'extraction d'images intrinsèques à partir de photographies est un problème difficile, généralement résolu en utilisant des méthodes de propagation guidée par l'image nécessitant de multiples indications utilisateur. Des méthodes récentes en vision par ordinateur permettent l'acquisition facile mais approximative d'informations géométriques d'une scène à l'aide de plusieurs photographies selon des points de vue différents. Nous développons un nouvel algorithme qui nous permet d'exploiter cette information bruitée et peu fiable pour automatiser et améliorer les algorithmes d'estimation d'images intrinsèque par propagation. En particulier, nous développons une nouvelle approche par optimisation afin d'estimer les ombres portées dans l'image, en peaufinant une estimation initiale obtenue à partir des informations géométriques reconstruites. Dans une dernière étape nous adaptons les algorithmes de propagation guidée par l'image, en remplaçant les indications utilisateurs manuelles par les données d'ombre et de réflectance déduite du nuage de points 3D par notre algorithme. Notre méthode permet l'extraction automatique des images intrinsèques à partir de multiples points de vue, permettant ainsi de nombreux types de manipulations d'images.
