A reconstruction of Kulik's "Magnus Canon Divisorum" (ca. 1825-1863)
Kulik's table of factors was supposed to give the smallest factor of all integers up to one hundred million. Kulik did not complete his table, which exists only in manuscript form, but it has been analyzed and finally reconstructed here.
kulik1863intro.pdf (16.65 Mo)
Télécharger le fichier
kulik1863vol1.pdf (29.98 Mo)
kulik1863vol2.pdf (32.09 Mo)
kulik1863vol3.pdf (40.66 Mo)
kulik1863vol4.pdf (40.64 Mo)
kulik1863vol5.pdf (40.73 Mo)
kulik1863vol6.pdf (40.81 Mo)
kulik1863vol7.pdf (42.36 Mo)
kulik1863vol8.pdf (42.68 Mo)
kulik1863xvol01.pdf (14.99 Mo)
kulik1863xvol02.pdf (15.08 Mo)
kulik1863xvol03.pdf (16.07 Mo)
kulik1863xvol04.pdf (16.12 Mo)
kulik1863xvol05.pdf (20.26 Mo)
kulik1863xvol06.pdf (20.28 Mo)
kulik1863xvol07.pdf (20.34 Mo)
kulik1863xvol08.pdf (20.39 Mo)
kulik1863xvol09.pdf (20.51 Mo)
kulik1863xvol10.pdf (20.47 Mo)
kulik1863xvol11.pdf (20.5 Mo)
kulik1863xvol12.pdf (20.52 Mo)
kulik1863xvol13.pdf (21.21 Mo)
kulik1863xvol14.pdf (21.38 Mo)
kulik1863xvol15.pdf (21.26 Mo)
kulik1863xvol16.pdf (21.41 Mo)
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
