Bifurcation from semi-trivial standing waves and ground states for a system of nonlinear Schrodinger equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Mathematical Analysis Année : 2012
We consider a system of nonlinear Schr¨odinger equations related to the Raman amplification in a plasma. We study the orbital stability and instability of standing waves bifurcating from the semi-trivial standing wave of the system. The stability and instability of the semitrivial standing wave at the bifurcation point are also studied. Moreover, we determine the set of the ground states completely.
Fichier non déposé
hal-00656237 , version 1 (03-01-2012)
  • HAL Id : hal-00656237 , version 1
Mathieu Colin, Masahito Ohta. Bifurcation from semi-trivial standing waves and ground states for a system of nonlinear Schrodinger equations. SIAM Journal on Mathematical Analysis, 2012, 44 (1), pp.206-223. ⟨hal-00656237⟩
102 Consultations
0 Téléchargements
