s'authentifier
version française rss feed
hal-00658612, version 1
Design & knowledge modeling - Knowledge modeling as design
Willemien Visser (, http://www-roc.inria.fr/eiffel/documents/VISSER%20Willemien%20FICHE%20en.html) 1
CCAI, Communication and Cognition - Artificial Intelligence (today entitled "CC-AI, The journal for the integrated study of Artificial Intelligence, Cognitive Science and Applied Epistemology") 10, 3 (1993) 219-233
Résumé : The paper presents a cognitive analysis of design as a problem-solving activity. Design is characterized through results from empirical studies of various design tasks. Based on this characterization, it will be argued why and how knowledge modeling can be considered as a design task. Knowledge modeling has been qualified as the "construction of a set of successive representations". Processing different types of representations at different levels and from different viewpoints plays an important role in design problem solving. It will be argued that other characteristics of design may also apply to knowledge modeling. As there are not yet data available on the cognitive activities involved in knowledge modeling, hypotheses for studying these activities may be inspired by what is known about design: design problems have no pre-existing, complete problem definition, and no unique, correct solution; the design activity does not follow a pre-existing plan, it is opportunistically organized.
  • Domaine : Sciences cognitives/Psychologie
    Sciences de l'Homme et Société/Psychologie
  • Mots-clés : Design – Knowledge modeling – Problem solving – Ill-defined problem – Cognitive modeling – Representations – Empirical studies – Conception – Modélisation de connaissances – Résolution de problème – Problèmes mal structurés – Modélisation cognitive – Représentation – Etudes empiriques
  • hal-00658612, version 1
  • oai:hal.inria.fr:hal-00658612
  • Contributeur :
  • Soumis le : Mardi 10 Janvier 2012, 17:07:27
  • Dernière modification le : Jeudi 12 Janvier 2012, 16:52:12
tous les articles de la base du CCSd...
