Time dilation have opposite signs in hemispheres of recession and approach
In this paper we give a detailed analysis of the factual observation that time dilation or Doppler shift of frequency are oppositely signed relative to our line of sight in different regions of motion. We show that this depends on how these regions are connected to the actual path of motion and to the location of the observer/detector. For a static globe or circle/sphere of reference, we define two hemispheres; shifts will be red-shifted in the hemisphere of recession and blue-shifted, or violet shifted, in the hemisphere of approach, a fact which is not often mentioned. Indeed, it is a complete sphere where the motion can take place with respect to the line-of-sight, which we have studied in this paper, not just the direction of motion along a certain specific path. The transverse and longitudinal effects are special cases of this general effect. The transverse effect is always red-shifted consistent with the known effect of Relativity and it lies at the intersection of the hemispheres of approach and recession. By saying moving clocks run slower we conveniently forget this important effect. They also run faster, in the hemisphere of approach. We demonstrate this important result from the basic principles of the Special Theory of Relativity
Time_dilation_have_opposite_signs_in_hemispheres_of_recession_and_approach.pdf (175.69 Ko)
Télécharger le fichier
