s'authentifier
version française rss feed
hal-00661591, version 1
Anti-sparse coding for approximate nearest neighbor search
Hervé Jégou (, http://www.irisa.fr/texmex/people/jegou) 1, Teddy Furon (, http://www.irisa.fr/texmex/people/furon/index_en.html) a1, Jean-Jacques Fuchs b2
ICASSP - 37th International Conference on Acoustics, Speech, and Signal Processing (2012)
Résumé : This paper proposes a binarization scheme for vectors of high dimension based on the recent concept of anti-sparse coding, and shows its excellent performance for approximate nearest neighbor search. Unlike other binarization schemes, this framework allows, up to a scaling factor, the explicit reconstruction from the binary representation of the original vector. The paper also shows that random projections which are used in Locality Sensitive Hashing algorithms, are significantly outperformed by regular frames for both synthetic and real data if the number of bits exceeds the vector dimensionality, i.e., when high precision is required.
  • a –  INRIA
  • b –  Université de Rennes I
  • 1 :  TEXMEX (INRIA - IRISA)
  • CNRS : UMR6074 – INRIA – INSA Rennes – Université de Rennes 1
  • 2 :  SIROCCO (INRIA - IRISA)
  • INRIA – CNRS : UMR6074 – Université de Rennes 1
  • Domaine : Informatique/Vision par ordinateur et reconnaissance de formes
  • hal-00661591, version 1
  • oai:hal.inria.fr:hal-00661591
  • Contributeur :
  • Soumis le : Vendredi 20 Janvier 2012, 10:29:34
  • Dernière modification le : Vendredi 23 Mars 2012, 10:20:08
tous les articles de la base du CCSd...
