Toward an Optimized Global-in-Time Schwarz Algorithm for Diffusion Equations with Discontinuous and Spatially Variable Coefficients, Part 2: the Variable Coefficients Case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Electronic Transactions on Numerical Analysis Année : 2013
This paper is the second part of a study dealing with the application of a global-in-time Schwarz method to a one dimensional diffusion problem defined on two non-overlapping subdomains. In the first part, we considered that the diffusion coefficients were constant and possibly discontinuous. In the present study, we address the problem for spatially variable coefficients with a discontinuity at the interface between subdomains. For this particular case, we derive a new approach to determine analytically the convergence factor of the associated algorithm. The theoretical results are illustrated by numerical experiments with Dirichlet-Neumann and Robin-Robin interface conditions. In the Robin-Robin case, thanks to the convergence factor found at the analytical level, we can optimize the convergence speed of the Schwarz algorithm.
Lemarie_ETNA2_2011.pdf (362.83 Ko) Télécharger le fichier
hal-00661978 , version 1 (22-01-2012)
  • HAL Id : hal-00661978 , version 1
Florian Lemarié, Laurent Debreu, Eric Blayo. Toward an Optimized Global-in-Time Schwarz Algorithm for Diffusion Equations with Discontinuous and Spatially Variable Coefficients, Part 2: the Variable Coefficients Case. Electronic Transactions on Numerical Analysis, 2013, 40, pp.170-186. ⟨hal-00661978⟩
404 Consultations
194 Téléchargements
