Invertible Program Restructurings for Continuing Modular Maintenance - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rémi Douence
Akram Ajouli
  • Fonction : Auteur
  • PersonId : 765331
  • IdRef : 172287197
When one chooses a main axis of structural decompostion for a software, such as function- or data-oriented decompositions, the other axes become secondary, which can be harmful when one of these secondary axes becomes of main importance. This is called the tyranny of the dominant decomposition. In the context of modular extension, this problem is known as the Expression Problem and has found many solutions, but few solutions have been proposed in a larger context of modular maintenance. We solve the tyranny of the dominant decomposition in maintenance with invertible program transformations. We illustrate this on the typical Expression Problem example. We also report our experiments with Java and Haskell programs and discuss the open problems with our approach.
CohenDouence.pdf (117.07 Ko) Télécharger le fichier
hal-00662777 , version 1 (25-01-2012)
Julien Cohen, Rémi Douence, Akram Ajouli. Invertible Program Restructurings for Continuing Modular Maintenance. 16th European Conference on Software Maintenance and Reengineering (CSMR 2012), Mar 2012, Szeged, Hungary. pp.347-352, ⟨10.1109/CSMR.2012.42⟩. ⟨hal-00662777⟩
485 Consultations
210 Téléchargements
