Study of a low Mach nuclear core model for single-phase flows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Proceedings Année : 2012
This paper deals with the modelling of the coolant (water) in a nuclear reactor core. This study is based on a monophasic low Mach number model (LMNC model) coupled to the stiffened gas law for a single-phase flow. Some analytical steady and unsteady solutions are presented for the 1D case. We then introduce a numerical scheme to simulate the 1D model in order to assess its relevance. Finally, we carry out a normal mode perturbation analysis in order to approximate 2D solutions around the 1D steady solutions.
CEMRACS-LMNCModel-BDFGLNP.pdf (595.44 Ko) Télécharger le fichier
hal-00662978 , version 1 (25-01-2012)
Manuel Bernard, Stéphane Dellacherie, Gloria Faccanoni, Bérénice Grec, Olivier Lafitte, et al.. Study of a low Mach nuclear core model for single-phase flows. ESAIM: Proceedings, 2012, 38, pp.118-134. ⟨10.1051/proc/201238007⟩. ⟨hal-00662978⟩
702 Consultations
352 Téléchargements
