T-coercivity: application to the discretization of Helmholtz-like problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2012
To solve variational indefinite problems, a celebrated tool is the Banach-Nečas- Babuška theory, which relies on the inf-sup condition. Here, we choose an alternate theory, T-coercivity. This theory relies on explicit inf-sup operators, both at the continuous and discrete levels. It is applied to solve Helmholtz-like problems in acoustics and electromagnetics. We provide simple proofs to solve the exact and discrete problems, and to show convergence under fairly general assumptions. We also establish sharp estimates on the convergence rates.
Jr12-final.pdf (640.56 Ko) Télécharger le fichier
hal-00664575 , version 1 (31-01-2012)
hal-00664575 , version 2 (06-02-2012)
hal-00664575 , version 3 (09-03-2012)
  • HAL Id : hal-00664575 , version 3
Patrick Ciarlet. T-coercivity: application to the discretization of Helmholtz-like problems. 2012. ⟨hal-00664575v3⟩
302 Consultations
651 Téléchargements
