Enhancing 3D Mesh Topological Skeletons with Discrete Contour Constrictions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The Visual Computer Année : 2008
Julien Tierny
Mohamed Daoudi
This paper describes a unified and fully automatic algorithm for Reeb graph construction and simplification as well as constriction approximation on triangulated surfaces. The key idea of the algorithm is that discrete contours - curves carried by the edges of the mesh and approximating the continuous contours of a mapping function - encode both topological and geometrical shape characteristics. Therefore, a new concise shape representation, enhanced topological skeletons, is proposed, encoding contours' topological and geometrical evolution. Firstly, mesh feature points are computed. Then they are used as geodesic origins for the computation of an invariant mapping function that reveals the shape most significant features. Secondly, for each vertex in the mesh, its discrete contour is computed. As the set of discrete contours recovers the whole surface, each of them can be analyzed, both to detect topological changes and constrictions. Constriction approximations enable Reeb graphs refinement into more visually meaningful skeletons, that we refer as enhanced topological skeletons. Extensive experiments showed that, without preprocessing stage, proposed algorithms are fast in practice, affine-invariant and robust to a variety of surface degradations (surface noise, mesh sampling and model pose variations). These properties make enhanced topological skeletons interesting shape abstractions for many computer graphics applications.
tiernyTVCJ2008preprint.pdf (4.37 Mo) Télécharger le fichier
hal-00666128 , version 1 (03-02-2012)
Julien Tierny, Jean-Philippe Vandeborre, Mohamed Daoudi. Enhancing 3D Mesh Topological Skeletons with Discrete Contour Constrictions. The Visual Computer, 2008, 24 (3), pp.155-172. ⟨10.1007/s00371-007-0181-0⟩. ⟨hal-00666128⟩
208 Consultations
224 Téléchargements
