Upper bounds for stabilization in acyclic preference-based systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Preference-based systems (p.b.s.) describe interactions between nodes of a system that can rank their neighbors. Previous work has shown that p.b.s. converge to a unique locally stable matching if an acyclicity property is verified. In the following we analyze acyclic p.b.s. with respect to the self-stabilization theory. We prove that the round complexity is bounded by n/2 for the adversarial daemon. The step complexity is equivalent to (n^2)/4 for the round robin daemon, and exponential for the general adversarial daemon.
10.1.1.95.9032.pdf (396.1 Ko) Télécharger le fichier
hal-00668356 , version 1 (09-02-2012)
  • HAL Id : hal-00668356 , version 1
Fabien Mathieu. Upper bounds for stabilization in acyclic preference-based systems. SSS'07 - 9th international conference on Stabilization, Safety, and Security of Distributed Systems, 2007, Paris, France. pp.372--382. ⟨hal-00668356⟩
108 Consultations
140 Téléchargements
