BugMaps: A Tool for the Visual Exploration and Analysis of Bugs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
To harness the complexity of big legacy software, software engineering tools need more and more information on these systems. This information may come from analysis of the source code, study of execution traces, computing of metrics, etc. One source of information received less attention than source code: the bugs on the system. Little is known about the evolutionary behavior, lifetime, distribution, and stability of bugs. In this paper, we propose to consider bugs as first class entities and a useful source of information that can answer such topics. Such analysis is inherently complex, because bugs are intangible, invisible, and difficult to be traced. Therefore, our tool extracts information about bugs from bug tracking systems, link this information to other software artifacts, and explore interactive visualizations of bugs that we call bug maps.
Mots clés
bugMaps-CSMR2012-FINAL-pdf-express.pdf (470.84 Ko) Télécharger le fichier
hal-00668397 , version 1 (09-02-2012)
  • HAL Id : hal-00668397 , version 1
Andre Hora, Nicolas Anquetil, Stéphane Ducasse, Muhammad Usman Bhatti, Cesar Couto, et al.. BugMaps: A Tool for the Visual Exploration and Analysis of Bugs. Proceedings of the 16th European Conference on Software Maintenance and Reengineering (CSMR'12) - Tool Demonstration Track, Mar 2012, Szeged, Hungary. ⟨hal-00668397⟩
225 Consultations
515 Téléchargements
