A Kernel Multiple Change-point Algorithm via Model Selection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Machine Learning Research Année : 2019
Sylvain Arlot
Alain Celisse
We tackle the change-point problem with data belonging to a general set. We build a penalty for choosing the number of change-points in the kernel-based method of Harchaoui and Cappé (2007). This penalty generalizes the one proposed by Lebarbier (2005) for one-dimensional signals. We prove a non-asymptotic oracle inequality for the proposed method, thanks to a new concentration result for some function of Hilbert-space valued random variables. Experiments on synthetic data illustrate the accuracy of our method, showing that it can detect changes in the whole distribution of data, even when the mean and variance are constant.
kernelchpt_hal_v3.pdf (1.16 Mo) Télécharger le fichier
hal-00671174 , version 1 (17-02-2012)
hal-00671174 , version 2 (18-03-2016)
hal-00671174 , version 3 (14-03-2019)
Sylvain Arlot, Alain Celisse, Zaid Harchaoui. A Kernel Multiple Change-point Algorithm via Model Selection. Journal of Machine Learning Research, 2019, 20 (162), pp.1--56. ⟨hal-00671174v3⟩
1371 Consultations
1066 Téléchargements
