s'authentifier
version française rss feed
hal-00671809, version 2
Construction of real algebraic numbers in Coq
Cyril Cohen () 123
ITP - 3rd International Conference on Interactive Theorem Proving - 2012 (2012)
Résumé : This paper shows a construction in Coq of the set of real algebraic numbers, together with a formal proof that this set has a structure of discrete archimedian real closed field. This construction hence implements an interface of real closed field. Instances of such an interface immediately enjoy quantifier elimination thanks to a previous work. This work also intends to be a basis for the construction of complex algebraic numbers and to be a reference implementation for the certification of numerous algorithms relying on algebraic numbers in computer algebra.
  • Domaine : Informatique/Autre
  • Mots-clés : coq – real algebraic numbers – formalization of mathematics – quotient – real closure – small scale reflexion
  • Versions disponibles :  v1 (19-02-2012) v2 (14-06-2012)
  • hal-00671809, version 2
  • oai:hal.inria.fr:hal-00671809
  • Contributeur :
  • Soumis le : Mercredi 13 Juin 2012, 23:24:43
  • Dernière modification le : Jeudi 14 Juin 2012, 11:24:29
tous les articles de la base du CCSd...
