s'authentifier
version française rss feed
hal-00672654, version 1
Numerical Accuracy Evaluation for Polynomial Computation
Naud Jean-Charles () a1, Daniel Menard () b1
N° RR-7878 (2012)
Résumé : Fixed-point conversion requires fast analytical methods to evaluate the accuracy degradation due to quantization noises. Usually, analytical methods do not consider the correlation between quantization noises. Correlation between quantization noises occurs when a data is quantized several times. This report explained, through an example, the methodology used in the ID.Fix tool to support correlation. To decrease the complexity, a method to group together several quantization noises inside a same noise source is described. The maximal relative estimation error obtained with the proposed approach is less than 2 %.
  • a –  INRIA
  • b –  Université de Rennes 1
  • 1 :  CAIRN (INRIA - IRISA)
  • INRIA – CNRS : UMR6074 – École normale supérieure de Cachan - ENS Cachan – Institut National des Sciences Appliquées (INSA) - Rennes – Université de Rennes 1
  • Domaine : Informatique/Traitement du signal et de l'image
    Sciences de l'ingénieur/Traitement du signal et de l'image
  • Référence interne : RR-7878
  • hal-00672654, version 1
  • oai:hal.inria.fr:hal-00672654
  • Contributeur :
  • Soumis le : Mardi 21 Février 2012, 16:37:31
  • Dernière modification le : Jeudi 23 Février 2012, 09:46:13
tous les articles de la base du CCSd...
