s'authentifier
version française rss feed
hal-00673801, version 3
Bayesian Pursuit Algorithms
Cedric Herzet () 1, Angélique Drémeau () 23
Résumé : This paper addresses the sparse representation (SR) problem within a general Bayesian framework. We show that the Lagrangian formulation of the standard SR problem, i.e. $\x^\star=\argmin_\x \lbrace \| \y-\D\x\|_2^2+\lambda\| \x\|_0 \rbrace$, can be regarded as a limit case of a general maximum a posteriori (MAP) problem involving Bernoulli-Gaussian variables. We then propose different tractable implementations of this MAP problem that we refer to as ''Bayesian pursuit algorithms". The Bayesian algorithms are shown to have strong connections with several well-known pursuit algorithms of the literature (e.g., MP, OMP, StOMP, CoSaMP, SP) and generalize them in several respects. In particular, i) they naturally allow for atom deselection; ii) they can include any prior information about the probability of occurrence of each atom within the selection process; iii) they can encompass the estimation of unkown model parameters into their recursions.
  • hal-00673801, version 3
  • oai:hal.inria.fr:hal-00673801
  • Contributeur :
  • Soumis le : Lundi 6 Août 2012, 11:10:22
  • Dernière modification le : Mardi 7 Août 2012, 08:56:57
tous les articles de la base du CCSd...
