Numerical homogenization of a nonlinearly coupled elliptic-parabolic system, reduced basis method, and application to nuclear waste storage - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Models and Methods in Applied Sciences Année : 2013
We consider the homogenization of a coupled system of PDEs describing flows in highly heterogeneous porous media. Due to the coupling, the effective coefficients always depend on the slow variable, even in the simple case when the porosity is taken purely periodic. Therefore the most important part of the computational time for the numerical simulation of such flows is dedicated to the determination of these coefficients. We propose a new numerical algorithm based on Reduced Basis techniques, which significantly improves the computational performances.
GGK.pdf (504.47 Ko) Télécharger le fichier
hal-00674519 , version 1 (27-02-2012)
hal-00674519 , version 2 (22-02-2013)
Antoine Gloria, Thierry Goudon, Stella Krell. Numerical homogenization of a nonlinearly coupled elliptic-parabolic system, reduced basis method, and application to nuclear waste storage. Mathematical Models and Methods in Applied Sciences, 2013, 23 (13), pp.1-33. ⟨10.1142/S0218202513500395⟩. ⟨hal-00674519v2⟩
618 Consultations
346 Téléchargements
