A Stochastic Collocation Method Combined With a Reduced Basis Method to Compute Uncertainties in Numerical Dosimetry - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Magnetics Année : 2012
Amine Drissaoui
  • Fonction : Auteur
  • PersonId : 915630
Philippe Lévêque
OSA
François Musy
  • Fonction : Auteur
  • PersonId : 836616
Laurent Nicolas
Ronan Perrussel
Damien Voyer
  • Fonction : Auteur
  • PersonId : 841634
A reduced basis method is introduced to deal with a stochastic problem in a numerical dosimetry application in which the field solutions are computed using an iterative solver. More precisely, the computations already performed are used to build an initial guess for the iterative solver. It is shown that this approach significantly reduces the computational cost.
tmag_48_2_563.pdf (369.57 Ko) Télécharger le fichier
hal-00675034 , version 1 (02-03-2012)
Amine Drissaoui, Stéphane Lanteri, Philippe Lévêque, François Musy, Laurent Nicolas, et al.. A Stochastic Collocation Method Combined With a Reduced Basis Method to Compute Uncertainties in Numerical Dosimetry. IEEE Transactions on Magnetics, 2012, 48 (2), pp 563-566. ⟨10.1109/TMAG.2011.2174347⟩. ⟨hal-00675034⟩
750 Consultations
237 Téléchargements
