Mean-field models for disordered crystals - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal de Mathématiques Pures et Appliquées Année : 2013
In this article, we set up a functional setting for mean-field electronic structure models of Hartree-Fock or Kohn-Sham types for disordered crystals. The electrons are quantum particles and the nuclei are classical point-like articles whose positions and charges are random. We prove the existence of a minimizer of the energy per unit volume and the uniqueness of the ground state density of such disordered crystals, for the reduced Hartree-Fock model (rHF). We consider both (short-range) Yukawa and (long-range) Coulomb interactions. In the former case, we prove in addition that the rHF ground state density matrix satisfies a self-consistent equation, and that our model for disordered crystals is the thermodynamic limit of the supercell model.
article.pdf (404.35 Ko) Télécharger le fichier
hal-00675594 , version 1 (02-03-2012)
Eric Cancès, Salma Lahbabi, Mathieu Lewin. Mean-field models for disordered crystals. Journal de Mathématiques Pures et Appliquées, 2013, 100 (2), pp.241-274. ⟨hal-00675594⟩
362 Consultations
209 Téléchargements
