Error estimates in approximate deconvolution models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Communications in Mathematical Sciences Année : 2013
We consider general Approximate Deconvolution Models (ADM). We estimate the error modeling as a function of the residual stress $\tau_N$ and we compute the rate of convergence to the mean Navier-Stokes Equations in terms of the deconvolution order $N$.
AD_RL_V2.pdf (159.73 Ko) Télécharger le fichier
hal-00675968 , version 1 (02-03-2012)
  • HAL Id : hal-00675968 , version 1
Argus Adrian Dunca, Roger Lewandowski. Error estimates in approximate deconvolution models. Communications in Mathematical Sciences, 2013, pp.11. ⟨hal-00675968⟩
556 Consultations
171 Téléchargements
