On local search for bi-objective knapsack problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Evolutionary Computation Année : 2013
In this article, a local search approach is proposed for three variants of the bi-objective binary knapsack problem, with the aim of maximizing the total profit and minimizing the total weight. First, an experimental study on a given structural property of connectedness of the efficient set is conducted. Based on this property, a local search algorithm is proposed and its performance is compared against exact algorithms in terms of running time and quality metrics. The experimental results indicate that this simple local search algorithm is able to find a representative set of optimal solutions in most of the cases, and in much less time than exact algorithms.
liefooghe_ecj2013.pdf (248.31 Ko) Télécharger le fichier
hal-00676625 , version 1 (02-03-2023)
Arnaud Liefooghe, Luis Paquete, José Rui Figueira. On local search for bi-objective knapsack problems. Evolutionary Computation, 2013, 21 (1), pp.179-196. ⟨10.1162/EVCO_a_00074⟩. ⟨hal-00676625⟩
193 Consultations
21 Téléchargements
