Decoding interleaved Reed-Solomon codes beyond their joint error-correcting capability - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Designs, Codes and Cryptography Année : 2014
A new probabilistic decoding algorithm for low-rate interleaved Reed-Solomon (IRS) codes is presented. This approach increases the error correcting capability of IRS codes compared to other known approaches (e.g. joint decoding) with high probability. It is a generalization of well-known decoding approaches and its complexity is quadratic with the length of the code. Asymptotic parameters of the new approach are calculated and simulation results are shown to illustrate its performance. Moreover, an upper bound on the failure probability is derived.
ZehWachterBezzateev_MinimumDistance_20120305.pdf (218.78 Ko) Télécharger le fichier
hal-00678646 , version 1 (13-03-2012)
Alexander Zeh, Antonia Wachter-Zeh, Martin Bossert. Decoding interleaved Reed-Solomon codes beyond their joint error-correcting capability. Designs, Codes and Cryptography, 2014, 71 (2), pp.261-281. ⟨10.1007/s10623-012-9728-9⟩. ⟨hal-00678646⟩
621 Consultations
289 Téléchargements
