The Byzantine Brides Problem
We investigate the hardness of establishing as many stable marriages (that is, marriages that last forever) in a population whose memory is placed in some arbitrary state with respect to the considered problem, and where traitors try to jeopardize the whole process by behaving in a harmful manner. On the negative side, we demonstrate that no solution that is completely insensitive to traitors can exist, and we propose a protocol for the problem that is optimal with respect to the traitor containment radius.
